Cisco UCS C220 M3 Rack Server motherboard amber led definitions
lancesr
UCS C220 M3 Rack Server Won't power up (in standby mode) Have a amber led on the side of Mem stick C1 See Photo I have looked at all Docs I could find. Anybody have any idea what it means ??   Thanks for any help.DSC00141.JPG
@lancesr hi, in standby mode, can you try to access CIMC? if it works, you can see the exact error details. also try to check any outputs in monitor. if you cannot see anything, most of the times, this meant to HW failure.
Good luck
KB
Pulkit Mittal
Amber LED means a fail hard drive.
https://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c220m3-sff-specsheet.pdf
If you find this useful, please mark it helpful and accept the solution.
Good luck
KB
