Cisco webex romm kit mini with cucm 11.0 status rejected
salah gobbaa
Hi All,
I need to register a Cisco webex romm kit mini with cucm 11.0 in third party device but the status is rejected.
I cannot do the upgrade for cucm now.
any help ?
2 Accepted Solutions
Why do u want to register it as third party. Install device package if it’s not showing. I have CS kit mini running on Cucm11.x.
Response Signature
I would recommended to upgrade CUCM to 11.5 on which Webex Room Kit Mini is supported. Even if you get this device registered as third party SIP endpoint, some of the features may not work.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
7 Replies 7
Check the firmware. Hope you configured the DN for CS kit.
Most probably it could be firmware. You can also try a factory reset.
Response Signature
Thank you for your reply,
Just For your information, i was configured the device as a thirt-party becouse the cucm 11.0 does not support the kit room mini.
Response Signature
Vaijanath Sonvane
Do you have all the settings configured as per below guide including Directory Number?
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_0_1/sysConfig/CUCM_BK_C733E983_00_cucm-system-configuration-guide-1101/Configure___Third_Party_SIP_Phones.pdf
Thank you,
yes exactly i did the same steps but it doesn't work.
The probleme is resolved after i did this config on SIP PROFILE:
activated Redirect by Application and Use Fully Qualified Domain Name in SIP Requests
