Create bunch of templates in conductor
Muaaz El Kamali
I want to create a bunch of templates and conference aliases in conductor. The idea is to create 50 conference aliases with different PIN for each.
Is there is any way to do that using command line or easy way instead of create both templates & aliases manually(it will be 100 steps)
Muaaz
Patrick Sparkman
It looks like you can only use the web interface to create conference templates and aliases.  There doens't appear to be any CLI or API commands related to conference configuration on the Conductor.
Patrick Sparkman
Yes I have been looking in CLI & API without luck. So the only way is through web interface
