11-13-2016 09:23 PM - edited 03-18-2019 06:35 AM
I recently ordered some license under TP-SMP-K9.
following is the odering list.
Then I received some E-delivery license.But there is NO PAK with LIC-SMP+and LIC-SMP-STARTERKIT.
Only LIC-VMCNDTR-PMP-PK ,LIC-EXPE-PMP-PAK ,LIC-CMS-PAK,LIC-SW-EXP-K9 ,LIC-EXP-E-PAK,LIC-CNDTR-PMP-K9,LIC-TMS-PMP-PAK,
I opened a case with licensing@cisco.com But Tac said there is NO PAK with these two license.If there is no PAK I can't have a valid option key.
How can I install SMP to Conductor now?
11-14-2016 07:54 AM
I'd suggest you contact your Account Manager and also continue to work with TAC on how to approach this issue, what exactly you're supposed to do etc.
11-14-2016 09:19 PM
Dear Patrick:
Thank you for your reply.
Do you know is there any difference between LIC-SMP+ and LIC-TP-SMP?
Accoding to the document in Cisco Multiparty Licensing At-a-Glance I can only find LIC-TP-SMP.
And accoding to the document in Cisco Multiparty Video Conferencing & Licensing there is a LIC-SMP+ under TP-SMP-K9.
I think it maybe the same licnese which can be added in Conductor.So Shared multiparty license should have a PAK or option key.
Am I right?
Waiting for your reply.
11-15-2016 08:18 AM
I looks like it could be a typo in the At a Glance document, where it says LIC-TP-SMP, that's probably meant to be LIC-SMP+.
Regarding the Conductor PAKs, I have no idea, you should contact your Account Manager and their team should be able to help sort out what you need or if there are any misunderstandings anywhere with how you're supposed to deploy Conductor with SMP+.
11-16-2016 09:44 PM
Dear Patrick:
I have contact my AM and TAC then soloved this problem.
Thank you anyway.
11-16-2016 10:07 PM
Whenever you find out what you're supposed to do, let us know.
12-15-2016 05:58 AM
Hi Hengduzhang,
I have the same issue.
Could you tell me please how do you resolve the problem ?
Best regards
Salim
12-15-2016 08:07 AM
I actually just recently purchased SMP+ myself, and received PAKs for each license (see below).
We migrated from SMP to SMP+, but I wouldn't think it would matter how you purchased SMP+.
12-15-2016 08:27 AM
Hi Patrick,
Thank you for your quick reply.
I open a case and they send me the correct PAK regarding TP-SMP-K9
Best regards
Salim
12-16-2016 06:41 AM
Hi Patrick,
I still have the same issue
In details, I purchase the followings
01 LIC-TP-SMP-EP
01 TP-SMP-K9 (starter kit)
We have
01 BE6000 where we install a T Conductor, CUCM, TMS
01 VTS (MM 410v)
Our purpose with the 2 licenses is the ability to have 2 meetings at a time.
As is mentioned in the Cisco Multiparty Conferencing and Licensing for CMR Premises, in case we purchase the first license, we need to purchase also the second one.
We do not receive the PAK for the first license until I open a ticket yesterday.
In my last answer I tell you that we receive the TP-SMP-K9 PAK but it was a mistake.
I receive also
01 PAK for LIC-VMCNDTR-PMP-PK
01 PAK FOR LIC-TMS-PMP-PAK
02 PAKs for LIC-EXPE-PMP-PAK
The support tell me that TP-SMP-K9 has no PAK and we have to use those PAKs
We generate a License key for the first PAK and obtain
LIC-CNDTR-PMP-B30
LIC-CNDTR-PMP-CL
LIC-CNDR-PMP-C2400
Do you have any idea on how to associate the other PAKs (with TMS and Expressway ?)
We add the license from the LIC-TP-SMP-EP to the T Conductor and we can reach a meeting room but only one endpoint can call. The second one is only in audio
Sali
12-16-2016 06:58 AM
Based on what I received when I ordered the SMP Starer Kit last year, the PAKs you should have received are:
If you only ordered 1 LIC-TP-SMP-EP, than you only ordered one SMP and not two. Are you trying to call into the same conference, or a different conference? Is Multiparty licensing enabled on Conductor?
12-16-2016 07:17 AM
Hi Patrick,
I read one of your old post here https://supportforums.cisco.com/discussion/12751021/telepresence-shared-multiparty-license-question
And I understand my mistake about the conference number (only 1). The problem is that a Cisco presale engineer confirm to me before we purchase that the TP-SMP-K9 provide also a SMP license. But it is another problem and I will discuss with him later
We add the LIC-TP-SMP-EP license in the Conductor and enable the Multiparty licensing (in Maintenance > Options keys).
I ask my colleague to check the configuration as I a not on site.
Salim
