Telepresence codec C40 recovery
Sergey Popov
Hello
I had error on web interface of C40. It was maintenance page with such recovery options as upgrade factory reset and something else.
Upgrade didn't help - on web interface still was only the maintenance page.
And after factory reset I can’t ping it. And I have error message on monitor (screenshot attached) which tells that factory reset can solve the issue.
Now I can do factory reset C40 only using the serial interface.
I find commands for this in the C40 guide (xCommand SystemUnit FactoryReset Confirm: Yes). But I have other commands in CLI:
 - User Commands -
help                factoryreset        log                 pkgverify
reboot              remotesupportuser   rootsettings        selectsw
startweb            version
I tried to use command factoryreset. CLI answers “OK” but nothing happens.
How can I do factory reset or some recovery?
Maybe it’s possible to reinstall soft for this codec?
Thank you.
5 Replies 5
Dmitry Beygul
You may need to upload the image through TFTP this is going to install a totally new image from scratch.
Dmitry
Hello Dmitry. Thank you for your reply and for this guide.
Now I try to assign IP to the codec
URL to files pkgextract.elf & u-boot.ini  from this document not works.
Does anybody have these files?
I had started upgrade without these files and I have big trouble now - Any image can't start and I don't have any access to codec.
Thank you
Hi Sergey,
For your info good document: https://supportforums.cisco.com/document/145446/tc-software-maintenance-mode
Do you try selectsw command ?
br Oleksandr
Hello Oleksandr. Thank you for your reply.
I tried this command. I have only one image:
selectsw
image2 - TC7.3.2 14ad7cc [ACTIVE] [SELECTED]
OK
