AA Script Mod - Direct xfer to VM
Darren Lynn
Hi All,
Ive been stgruggling with the use of the xfermailbox.aef correct use since the change in 8.6.1.
Ive attached the script below. Essentially what im looking to do it xfer all calls directly to a Reception Voicemail Mailbox during business close times.
General Delivery Mailbox ext is 950
I also need to incorporate a Night Switch option so if the reception hunt group is ever required to be unattended the calls can be switched directly to the Voicemail Mailbox. Im not sure if this is a scripted parameter or an override to the hunt group some how.
Any help is appreciated.
5 Replies 5
Darren Lynn
Hi All,
further testing is indicating that the Main Menu greeting isnt playing and the call gives fast busy and disconnect. Can this also be looked at?
Ive been working on a few other options with this script.
Im now trying to work on a night switch option. Ive been following the guide http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity_exp/rel7_0/administrator/script/nssamp.html
but the first if statement calls up a boolean expression that isnt defined.
Has anyone implemented a night switch option?
I found a work around so i dont have to rely on the xfermailbox.aef script
what was your workaround option?
HI Lewis,
My work around was to point the redirection required to a DN on UCE. say EXT 150.
I then had extension 150 set to CFA to voicemail
Because the calling number to VM (150) is a dummy number and i need the call to go to the group mailbox (ext 950) i had to create a translation rule to translate 150 to 950.
That translation rule was then configured in a translation profile attached to the dial peer to the CUE module.
configuration is something similar to this on the voice router. note that ive only included the configuration pertinent to the solution
ephone-dn 150 dual-line
number 150
call-forward all 900
voice translation-rule 1
rule 1 /150/ /950/
voice translation-profile CALL-VM
translate redirect-called 1
dial-peer voice 900 voip
translation-profile outgoing CALL-VM
destination-pattern 900
