AA Script with option to send to VoiceMail
Oskr220890
Hello Everybody,
I need some help,
I'm just applying this Script to deploy a Call Menu in Unity Express over a CME but there is a step that i'm not so sure that could be deployed , I need a Submenu with an If condition that redirects to a menu if the call is not answered, the options are:
1.- Leave Voice Mail
2.- Back to previous Menu
3.- Back to Main Menu
I think that steps 2 and 3 are not difficult but i can't think about a way to monitor the call if is not answered and then redirect to this new options and block the process that send the call to VoiceMail after a No Answer of the line.
Thanks in advance.
I'm attaching the Script that is running now.
keglass
Level 7
Level 7
Oscar,
I recommend you also post this to the Cisco Support Community for additional feedback and information.
I hope this helps. Thank you for participating in the community.
Kelli Glass
Moderator for Cisco Customer Communities
I did it, but i still dontá have an answer, Thanks.
