02-15-2016 09:46 AM - edited 03-19-2019 10:44 AM
I am setup CUC 10.5.2 and Office 365 for emails. attached are the snapshots what i have done but voicemail to email isn't working.
what can be the issue on this? I didn't make anything in office365 end.
please help to fix the issue. thank you so much.
02-25-2016 02:11 PM
Haider
Ensure you have the proper service account (impersonator) settings appropriately set. Need correct service account pwd. From your screen shots it looks like a authentication issue
I recently configured 2 CUC R11 clusters hence once the O365 engineer provided the correct credentials the system began to work as expected.
02-26-2016 11:29 AM
03-01-2016 05:59 AM
i suspect the impersonation account or passwords are not set correctly
03-01-2016 01:12 PM
Make sure your exchange server name smtp.office365.com is correct. Check the DNS entries forward and reverse both are working fine for smtp.office365.com. If these two things are OK, then select the option "Search for Hosted Exchange Servers Active Directory DNS Domain Name " instead of "Specify the Hosted Exchange Server" that's it.
Also first do the test on same O365 integration page and see if it is working or not.
03-01-2016 01:24 PM
Hi Rizwan,
I will recommend following a nice document posted on Cisco Site. Please find the link below.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unity-connection/118828-config-cuc-00.html
VJ
