CUCM 5 Web Login
hajosnorbert
Dear community,
I found two old CUCM 5.x server in the warehouse. I can login into the CLI+SSH, but I can not login into Callmanager Administration Website.
I tried to utils reset_ui_administrator_password, but I not able to login into web. I tried the admin, Admin, administrator, Administrator as user, but still says Logon failed.
The 2 server in cluster (publisher and subscriber).
How can I log into the webpage?
Norbert
2 Accepted Solutions
just a guess
try using  ccmadministrator
regds,
aman
you can refer the link:
http://docwiki.cisco.com/wiki/Cisco_Unified_Presence,_Release_7.x_--_Changing_the_Cluster_IP_Addresses_for_Subscriber_Servers_Defined_by_IP_Addresses#Changing_the_Cluster_IP_Addresses_for_Subscriber_Servers_Defined_by_IP_Addresses
set network ip eth0
9 Replies 9
Chris Deren
Is "utils reset_application_ui_administrator_name" available on your CUCM as I don't recall if this was available in version 5?
No, there is not this command available.
How about "Set Password Admin"
https://voiceonbits.com/2010/07/04/scenario3-change-of-administrator-username-password/
Still logon failed :(
just a guess
regds,
aman
You are won!
Thanks!
Little question:
How can I change the two node's IP addresses? Where can I do it?
set network ip eth0
I forget it:
Thanks, it works!
Brandon Buffin
Take a look at the password recovery steps here:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/100799-callmanager-5x-osadmin.html
Brandon
