CUCM/CUBE Inbound Call Drop - Multicast MOH
Jason Nash
Hi All,
I am working on migrating our gateways from ISDN to SIP using SIP trunks from Virgin media. I have all working well apart from an issue with MOH on inbound calls causing the call to drop.
Call fllow as follows..
IP Phone > CUCM > SIP > CUBE > SIP > PSTN/Virgin Media
We use a mutilcast MOH source from CUCM. When I place an inbound call on hold the call drops. If I disable MOH then there are no issues with hold tones. Initially I had the same issue with outbound calls but adding 'midcall-signaling passthru media-change' globally resovled this but only for outbound calls.
Here are the relevant sections of our config...
Version 15.5(3)M7
voice service voip
ip address trusted list
   ***REMOVED***
address-hiding
dtmf-interworking rtp-nte
mode border-element license capacity 60
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  rel1xx disable
  min-se 360 session-expires 360
  header-passing
  subscription maximum originate 2
  no update-callerid
  early-offer forced
voice class codec 1
codec preference 1 g711alaw
dial-peer voice 90 voip
description *** OUTBOUND DP to Virgin ***
translation-profile outgoing OutboundCallingPartyPrefix
preference 2
destination-pattern .T
session protocol sipv2
session target ipv4:***REMOVED***
session transport udp
voice-class codec 1
voice-class sip options-ping 60
voice-class sip options-keepalive retry 3
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte
ip qos dscp cs3 signaling
no vad
dial-peer voice 9991 voip
description *** OUTBOUND Emergency DP to Virgin ***
preference 1
destination-pattern 999
voice-class codec 1
voice-class sip options-keepalive down-interval 60 retry 3
dtmf-relay rtp-nte
no vad
dial-peer voice 1002 voip
description *** Dialed Extensions -> CUCM ***
translation-profile outgoing InboundCallingPartyPrefix9
destination-pattern 1...
session server-group 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 10 voip
description *** Incoming IP PBX (CUCM) ***
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 909 voip
description *** OUTBOUND Backup DP to Virgin Via Secondary CUBE ***
preference 3
dtmf-relay h245-alphanumeric
codec g711alaw
no vad
dial-peer voice 9 voip
description *** INBOUND Dial-Peer from Virgin ***
incoming called-number 1...
voice-class codec 1
dtmf-relay rtp-nte
no vad
Here is the call log for an inbound call which dropped as soon as placed on hold...
Apr  6 10:29:20.907: //16433/31A5D93B807E/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x22AEC928
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 9XXXXXXXXXXX
Called Number            : 1XXX
Source IP Address (Sig  ): ***CUBE IP***
Destn SIP Req Addr:Port  : ***CUCM PUB IP***:5060
Destn SIP Resp Addr:Port : ***CUCM PUB IP***:5060
Destination Name         : ***CUCM PUB IP***
Apr  6 10:29:20.907: //16433/31A5D93B807E/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 2
Media Stream             : 1
Negotiated Codec         : g711alaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 8 (tx), 8 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): ***CUBE IP***
Source IP Port    (Media): 16500
Destn  IP Address (Media): ***IP Phone IP***
Destn  IP Port    (Media): 17282
Orig Destn IP Address:Port (Media): [ - ]:0
Media Stream             : 2
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Port    (Media): 0
Destn  IP Address (Media): 0.0.0.0
Destn  IP Port    (Media): 0
Apr  6 10:29:20.935: //16431/31A5D93B807E/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x22B0CC00
Calling Number           : XXXXXXXXXXX
Source IP Address (Sig  ): ***CUBE VMB INT***
Destn SIP Req Addr:Port  : ***Virgin SBC***:5060
Destn SIP Resp Addr:Port : ***Virgin SBC***:5060
Destination Name         : ***Virgin SBC***
Apr  6 10:29:20.935: //16431/31A5D93B807E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Address (Media): ***CUBE VMB INT***
Source IP Port    (Media): 16498
Destn  IP Address (Media): ***Virgin SBC2***
Destn  IP Port    (Media): 10272
Maltings_2911_1#
Media Stream             : 2
Destn  IP Address (Media): ***Virgin SBC3***
Maltings_2911_1#
Apr  6 10:29:24.175: //16433/31A5D93B807E/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
Apr  6 10:29:24.175: //16433/31A5D93B807E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Media Stream             : 2
Source IP Port    (Media): 16502
Disconnect Cause (CC)    : 86
Disconnect Cause (SIP)   : 500
Apr  6 10:29:24.183: //16431/31A5D93B807E/SIP/Call/sipSPICallInfo:
Apr  6 10:29:24.183: //16431/31A5D93B807E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Maltings_2911_1#
Media Stream             : 2
Disconnect Cause (CC)    : 65
Disconnect Cause (SIP)   : 200
Any ideas where to go next with this?
14 Replies 14
Kevin Martin
Do you have the following commands on the CUBE?
ccm-manager music-on-hold
ip multicast-routing
Also, multicast routing would need to be enabled on Layer 3 devices between CUCM and the CUBE.
***Please Mark and Rate helpful posts***
Hi Kevin,
Yes, these are in place. The multicast MOH works as expected on outbound calls. Whilst the call is held if I take a look at 'sh ccm-manager music-on-hold' I can see the active multicast MOH stream.
As soon as I place an inbound call on hold the call drops.
Jason
Try adding this to your "Voice Service Voip > SIP" config:
No luck i'm afraid. This is how the call flow looks for an inbound call that is placed on hold and then drops with a disconnect cause 86 from Cube to CUCM.
Hi Jason,
did you configure the following (just an example):
dspfarm profile 1 transcode
maximum sessions 10
association aplication CUBE
dspfarm profile 2 mtp
maximum sessions 10
Best regards,
Marcelo Morais
Thanks Marcelo. No, we didnt have any local transcoding on the CUBE, altough we did have software MTPs and hardware transcoding resources assigned in CUCM. I have added local MTP and XCODE as in your example onto the CUBE but the same issue still exists.
Hi Jason,
there is a BYE (102 BYE) at 21:08:26.257, this is the communication between CUBE and CUCM?
Please use the following debugs and upload the result:
debug ccsip message
debug ccsip events
debug ccsip error
debug ccsip media
debug voip ccapi inout
debug ccsip info
Best regards,
Marcelo Morais
Thanks Marcelo. As soon as I enable that level of debugging the router slows to a halt and I have to power cycle. ccsip messages alone is not an issue but one or a combination of those causes issue. Ill see if I can work out which debug command is the issue.
You are correct that the 102 message is from CUBE to CUCM.
Just to add all works fine if I add a MTP required to the SIP trunks but I was trying to avoid doing this.
Hi Jason,
about "... all works fine if I add a MTP Required to the SIP Trunks ..." , in other words, if you select the the MTP Required on the CUCM > ... > SIP Trunk then all works fine, if my understanding is correct ... your CUBE uses G711 alaw and your CUCM (alaw or ulaw)?
Best regards,
Marcelo Morais
CUCM uses G711 ulaw. In order for it to work with MTP required I also needed to set the MTP Preferred Originating Codec on the CUCM SIP trunk to alaw or add G711 ulaw as a prefered code on the CUBE.
We are only looking at 60 concurrent calls here am I best just leaving the trunks with MTP required for all calls? I was trying to avoid having to enable MTP required for all calls.
Marcelo. I'd rather not publish the full logs here so I have just mailed them over to you.
Hi Jason,
1) Who is 192.168.238.102?
2) How did you configure your Multicast MoH (in CUCM and GW)?
PS.: double check if you are using G711alaw (G711ulaw is the first option for Multicast MoH)
3) In CUCM > System > Service Parameters > Cisco IP Voice Media Stream App, double check the Supported MoH Codec
Some info from the debug:
004469: Apr 10 22:59:40.389: //213407/4953D06F8217/SIP/Info/critical/10240/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
004470: Apr 10 22:59:40.389: //213407/4953D06F8217/SIP/Info/critical/8192/sipSPI_ipip_IsContentPassthruEnabled:  - 0
004471: Apr 10 22:59:40.389: //213407/4953D06F8217/SIP/Info/notify/8192/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
004580: Apr 10 22:59:40.397: //213407/4953D06F8217/SIP/Info/verbose/1/codec_found: Codec to be matched: g711ulaw(5)
004581: Apr 10 22:59:40.397: //213407/4953D06F8217/SIP/Info/notify/1/codec_found: Match Not Found for g711ulaw.
004582: Apr 10 22:59:40.397: //213407/4953D06F8217/SIP/Media/sipSPISelectCodecVersion: Codec (g729r8) is not in preferred list
004797: Apr 10 22:59:40.405: //213409/4953D06F8217/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 192.168.223.235, lport = 19228, raddr = 192.168.238.102, rport=22580, do_rtcp=FALSE
src_callid = 213409, dest_callid = 213407, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = 0.0.0.0, vrf tableid = 0 media_addr_type = 1 negotiated_bandwidth (kbps) = 0 srtp_services = 0 nat_flag = 0
004826: Apr 10 22:59:40.409: //213409/4953D06F8217/SIP/Info/notify/1/sipSPI_ipip_codec_byte_transrating: codec class not supported in xrating scenario, return FALSE
004960: Apr 10 22:59:40.421: //213409/4953D06F8217/SIP/Info/critical/1/sipSPIValidateConnectionAddress: dead stream since destination port is 0 for the m-line : 1
SIP: Group (a= group line) attribute, level 65535 instance 1 not found.
004967: Apr 10 22:59:40.421: //213409/4953D06F8217/SIP/Info/critical/10240/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
Note: did you try using the G711ulaw from CUBE to CUCM to check the results?
Best regards,
Marcelo Morais
Thanks.
238.102 is the IP endpoint, in this case a Cisco Jabbter softphone. Although the issue and log is the same for a 7945 handset also.
Multicast MOH is streamed from CUCM, setup as usual in the media resource list/group and assigned to both the endpoint and trunk. Multicast MOH is working as on an outbound call (and our ISDN gateways) hold is working as expected and I can see the multicast MOH stream as below. It just does not work on inbound calls.
sh ccm-m mus
Current active multicast sessions : 1
Multicast      RTP port  Packets      Call  Codec    Incoming
Address        number    in/out        id              Interface
239.1.0.0        16384  155/155          752  g711ulaw  Gi0/2
Above example is where I enabled ulaw from CUBE to CUCM, you can also see below it works fine on onbound with alaw too.
sh ccm-m mus
239.1.0.1        16384  423/423          820  g711alaw  Gi0/2
We have 711 mulaw and alaw selected as supported MOH codends in service parameters.
Taking a look at the trace.. the issue I can see is here...
Received:
ACK sip:9078XXXXXXXX@192.168.223.234:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.223.243:5060;branch=z9hG4bK73952177e519b0
From: <sip:1640@192.168.223.243>;tag=8887256~3d5fcf4e-c5df-4451-9da8-bf45984ad2c3-58499133
To: <sip:9078XXXXXXXX4@192.168.223.234>;tag=252B78-219A
Date: Wed, 11 Apr 2018 08:37:32 GMT
Call-ID: 657225F9-3C9A11E8-826CC7BB-2A84011C@192.168.223.234
User-Agent: Cisco-CUCM10.5
Max-Forwards: 70
CSeq: 102 ACK
Allow-Events: presence
Content-Type: application/sdp
Content-Length: 298
v=0
o=CiscoSystemsCCM-SIP 8887256 3 IN IP4 192.168.223.243
s=SIP Call
c=IN IP4 0.0.0.0
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 0 RTP/AVP 0
m=audio 0 RTP/AVP 0 8
a=X-cisco-media:mmoh
a=ptime:20
a=rtpmap:0 PCMU/8000
a=inactive
a=rtpmap:8 PCMA/8000
a=inactive
006208: Apr 11 09:37:32.448: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
006209: Apr 11 09:37:32.448: //605/656DE0498266/SIP/Info/info/4096/sipSPICheckFromToRequest: Found matching CB 239B1258
006210: Apr 11 09:37:32.448: //605/656DE0498266/SIP/Info/info/4096/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
006211: Apr 11 09:37:32.448: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x2208D840) counter, current msg->refCount = 2
006212: Apr 11 09:37:32.452: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Retaining configured TimeZone BST
006213: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/info/4096/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
006214: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/verbose/4096/sipSPIProcessIncomingAckForMidCall: Transaction Complete. Lock on Facilities released..
006215: Apr 11 09:37:32.452: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x3F462E00) counter, current msg->refCount = 1
006216: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/verbose/9216/sipSPIProcessNotifyCallInfoHeader: Processing Unsolicited Notifyfrom ACK SDP even though Call-Info header not there in ACK
006217: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/verbose/1/sipSPIDoMediaNegotiation: Number of m-lines = 2
006218: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/verbose/1/sipSPIValidateConnectionAddress: Dest port = 0
SIP: Attribute mid, level 1 instance 1 not found.
006219: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
006220: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
006221: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.223.234
006222: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/critical/1/sipSPIValidateConnectionAddress: dead stream since destination port is 0 for the m-line : 1
006223: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Error/sipSPIDoMediaNegotiation:
Failed to negotiate main stream. Main stream dead
006224: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Error/sipSPIProcessAckMedia:
Disconnecting due to MediaNego failure
006225: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/critical/4096/ccsip_set_cc_cause_for_spi_err: Categorized cause:65, category:278
006226: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/verbose/4096/ccsip_set_release_source_for_peer: ownCallId[605], src[6]
006227: Apr 11 08:37:32.452: %VOICE_IEC-3-GW: SIP: Internal Error (ACK, codec mismatch): IEC=1.1.278.7.108.0 on callID 605 GUID=656DE0493C9A11E88266C7BB2A84011C
006228: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/verbose/10240/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
006229: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/critical/10240/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
006230: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/critical/8192/sipSPI_ipip_IsContentPassthruEnabled:  - 0
006231: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/notify/8192/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
006232: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/critical/4096/ccsip_api_request_answer: Could not add hdrs for ev:1
006233: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/verbose/4096/ccsip_api_request_answer: ACK handling retval: SIP_UNACCEPTABLE_MEDIA_ERR
006234: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/info/4096/sipSPIProcessIncomingAckForMidCall: ccsip_api_request_answer returned: SIP_UNACCEPTABLE_MEDIA_ERR
006235: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/critical/4096/sipSPIInitiateDisconnect: Initiate call disconnect(65) for outgoing call
006236: Apr 11 09:37:32.452: //605/656DE0498266/SIP/Info/verbose/256/sipSPIResetXcoder: *****CLEANING UP XCODER RESOURCES*****
006237: Apr 11 09:37:32.452: //605/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
I have already tried using 711ulaw from CUBE to CUCM/CUCM to CUBE but the same issue still remains.
Jason Nash
This issue turned out to be a bug. I didn't find an identical bug but a few similar. This was resolved by updating CUCM to 10.5.2.16901-1.
