CUCM Lab Bundle
JayHenderson
Hi everyone,
I'm in the process of putting together a lab configuration and I need to know what is included in the following top level SKU:
CM9.0-K9-LAB
I'm looking for a list of the components (i.e. CUCM, UnityConnect, etc...) as well as the number of user licenses.
Thanks in advance!
Jay
skilambi
CM9.0-K9-LAB
SW CM 9.0 Lab Only, 20 CUWL PRO, 5 TP Room
Uconn
R-UNITYCN9-K9-LAB
Unity Connection 9.x Software, 200 users, Max Ports
There is nothing for CUP or UCCX
This is covered in the ordering guides
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/messaging_ordering_guide.pdf
CUCM I never found it not sure why they took it out it used to be in the 8.X OG, unless I missed it
Srini
Hi Srini,
For lab setup, this will allow me integrate with Cisco ATA?
CM9.0-K9-LABSW CM 9.0 Lab Only  20 CUWL PRO  5 TP Room
Thanks!
-JT-
Yes it will
Srini
