CUEAC BD Purge issue
alassonde
After starting a DB purge from the WEB interface for a lot of record
The report DB purge list , show In progress still from march  2017 when i start it
How can i kill this process ?
How can i manually purge DB ?
If i start a new purge, it work but it's very slow maybe because of the last one stil in progress
keglass
Level 7
Level 7
Alexandre,
I recommend you also post this to the Cisco Support Community for feedback and information from technical experts.
https://supportforums.cisco.com/
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
