How to set Path for SFTP in CUCM Disaster Recovery?
Aun Iqbal
hi guys,
I am trying to restore backup on my cucm and unity connection through disaster recovery.
so I am trying to create a BACKUP DEVICE NAME first.
My sftp server is runnning on my laptop. its named SFTPSERVER
I need to enter the following info in CUCM Disaster recovery screena dn not sure what to enter in PATH (as its not accepting anything....
server name = SFTPSERVER (name of my SFTP server)
Path name = C:\sftpfile\ (is this the correct format or there is anotherone.... I also tried with \\SFTPSERVER\)
User name = admin (as it is set on my server)
password = cisco (as it is set on my server)
I think there is a problem with my path name. I am using titanFTP...
Please help.
Many thanks :)
Jaime Valencia
usually you define an SFTP folder within the program that is in your laptop.
then, that is the base directory so you just reference it as . or /
if you have another folder within the root SFTP then you add it to the path you're using
java
if this helps, please rate
java
Jaime Valencia
java
java
thanks dude, I changed my software.
It works fine with free sftpd and much better software :)
and youa re right, just use \ for directory if you ahvent made any changes to sftp software :)
what sftp did you use please ?, i can't find one that work !!!
