IM Presence 11.5 Second Node fails in installation.
Im trying to install CUP second node and there is not way to finish the installation.
The error is: Critical Error. The installation has encountered a unrecoverable internal error.
"/usr/local/cm/script/cm-cup-dbl-inetall Install PostInstall 11.5.1.13900-57.....
The system will now halt
Node conectivity check is OK, Validation with CUCM is OK, Validation with CUP is Ok but some time later it fails.
The problem is I have not access to the vcenter to deploy the ova. I send instructions to other people to deploy it. But CUP Publisher has installed correctly using the same OVA and ISO.
I have the CUP second node IP on System>Server correctly in CUCM.
The DNS are configure for this server.
Do I have to do anything in else?
I have deleted the Server on CUCM and restart publisher, deploy the CUPs ova and try agian but the issue persist.
I have no access to the instalation logs sorry.
Any ideas?
Thank you
Best Regards
Aman Soi
Hi ,
Just guessing : Check for NTP reachability and Stratum on CUCM PUB/SUB and IPM first Node.
regds,
aman
Can u read this discussion which related to bug for passwords
CUC/CUCM 11.5(1) does not support passwords longer than 15 characters
CSCvb00248
https://supportforums.cisco.com/t5/ip-telephony/im-presence-installation-11-5-1-11900-unrecoverable-internal/td-p/3066727
regds,
aman
Thanks for the answers. Finally I was able to install CUPs SUB.
l set "all" on the Incoming and Ougoing ACL in CUP PUB .
Also The Cisco Sync Agent service was "not running" so I started it and reload the PUB.
Probably It was a lack of configuration in PUB.
Best Regards
thanks for update.
regds,
aman
