Incoming call from Outside didn't work
alinewhorizons
Dears,
I have PSTN >> FXO voice-ports ( h323 VG ) >> CUCM
i want to make call from outside to the internal ip phones and i want them to ring once any one call from outside
i already implemented dial-peers, connection plar command and route patterns on cucm .. i can call from inside to any outside number
but my problem with the incoming calls >> and if i want any one call from outside get an opening greeting what do i need to configure ?
please advice
Thank you all
What partition is the DN in?  What CSS is assigned to the H323 Gateway and does that CSS list this partition in it? If you prefer please provide screen shots of the DN, H323 GW and the CSS.
10 Replies 10
Chris Deren
Please post "debug voice ccapi inout", "debug vpm signal" and "sh run".
For auto attendant redirection the plar destination needs to be defined in CUCM to point to either Unity where it hits a call handler, or UCCX application.
Aug 29 12:03:56.123: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=599212133, Called Number=, Voice-Interface=0x2CDFFBD4,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
Aug 29 12:03:56.123: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Aug 29 12:03:56.123: //-1/DBA901798024/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=599212133
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=0
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Aug 29 12:03:56.123: //-1/DBA901798024/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2CDFFBD4, Call Info(
   Calling Number=599212133,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=PSTN, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
   Interface Type=2, Protocol=0
Aug 29 12:03:56.123: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 29 12:03:56.123: :cc_get_feature_vsa malloc success
Aug 29 12:03:56.123:  cc_get_feature_vsa count is 1
Aug 29 12:03:56.123: :FEATURE_VSA attributes are: feature_name:0,feature_time:735469160,feature_id:20
Aug 29 12:03:56.123: //20/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=1
Aug 29 12:03:56.123: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
Aug 29 12:03:56.123:  call_init_entry calle is 2BD5F230,callid is 20
Aug 29 12:03:56.123: //20/DBA901798024/CCAPI/cc_init_call_entry:
Aug 29 12:03:56.123: //20/DBA901798024/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=20
Aug 29 12:03:56.123: //20/DBA901798024/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=599212133(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0(TON=Unknown, NPI=Unknown))
Aug 29 12:03:56.123: //20/DBA901798024/CCAPI/cc_api_insert_call_active_entry:
Aug 29 12:03:56.123: //20/DBA901798024/CCAPI/cc_incr_if_call_volume:
Aug 29 12:03:56.123: //20/DBA901798024/CCAPI/cc_process_call_setup_ind:
   Event=0x310EE630
Aug 29 12:03:56.123: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=0, Call Transfer Consult Id=
Aug 29 12:03:56.123: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Searching Node;
Aug 29 12:03:56.123: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
Aug 29 12:03:56.123: Comparing SSOpCode; 0x50 and 0x0
Aug 29 12:03:56.123: Comparing SSOpCode; 0x12 and 0x0
   Try with the demoted called number 0
   No Matching Node
Aug 29 12:03:56.123: //20/DBA901798024/CCAPI/ccCallSetContext:
   Context=0x318EBD3C
   >>>>CCAPI handed cid 20 with tag 0 to app "_ManagedAppProcess_Default"
Aug 29 12:03:56.123: //20/DBA901798024/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Aug 29 12:03:56.127: //-1/DBA901798024/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=0, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=0
   Result=Success(0) after DP_MATCH_DEST
Aug 29 12:03:56.127: //-1/DBA901798024/DPM/dpMatchSafModulePlugin:
   dialstring=0, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Aug 29 12:03:56.127: //-1/DBA901798024/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=14
     2: Dial-peer Tag=13
   Result=SUCCESS(0)
     1: Dial-peer Tag=14
     2: Dial-peer Tag=13
Aug 29 12:03:56.127: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=0, Called Number=0, Peer Info Type=DIALPEER_INFO_SPEECH
Aug 29 12:03:56.127: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 29 12:03:56.127: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=14
     2: Dial-peer Tag=13
Aug 29 12:03:56.127: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=0, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=14
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Aug 29 12:03:56.127: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
   VALIDATING MLPP INFO:- ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
   Unsupported MLPP Service Domain Network 0
Aug 29 12:03:56.127: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
   Invalid MLPP Information
Aug 29 12:03:56.127: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
   Precedence not above Routine
Aug 29 12:03:56.127: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
   BEFORE COPY - SRC MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
   DEST  MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
     AFTER COPY - SRC MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]   DEST MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)]
   Result=SUCCESS(0)
     1: Dial-peer Tag=14
     2: Dial-peer Tag=13
   VALIDATING MLPP INFO:- ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)]
   dialstring=0, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=14
     2: Dial-peer Tag=13
Aug 29 12:03:56.127: //20/DBA901798024/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=14, Params=0x318D3A6C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Aug 29 12:03:56.127: //20/DBA901798024/CCAPI/ccCheckClipClir:
   In: Calling Number=599212133(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Calling Party Number Is User Provided
   Out: Calling Number=599212133(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=0, Called Number=0, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=DBA90179-4D7C-11E5-8024-BB6D126A5FF8, Outgoing Dial-peer=14
Aug 29 12:03:56.131: //20/DBA901798024/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=599212133
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=0
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Aug 29 12:03:56.131: //20/DBA901798024/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3106291C, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=599212133,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=14, Call Count On=FALSE,
   Source Trkgrp Route Label=PSTN, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
Aug 29 12:03:56.131: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 29 12:03:56.131: :cc_get_feature_vsa malloc success
Aug 29 12:03:56.131:  cc_get_feature_vsa count is 2
Aug 29 12:03:56.131: :FEATURE_VSA attributes are: feature_name:0,feature_time:735469384,feature_id:21
Aug 29 12:03:56.131: //21/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
Aug 29 12:03:56.131: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
Aug 29 12:03:56.131:  call_init_entry calle is 2BD5FEA8,callid is 21
Aug 29 12:03:56.131: //21/DBA901798024/CCAPI/cc_init_call_entry:
Aug 29 12:03:56.131: //20/DBA901798024/CCAPI/cc_peer_bind:
   Bind=TRUE, Binder Call Id=20, Bindee Call Id=21
Aug 29 12:03:56.131: //21/DBA901798024/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=21
Aug 29 12:03:56.131: //21/DBA901798024/CCAPI/cc_set_voice_port_value:exit@2153
Aug 29 12:03:56.131: //20/DBA901798024/CCAPI/ccIsCallConnectedByHandler:
Aug 29 12:03:56.131: //21/DBA901798024/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Aug 29 12:03:56.131: //20/DBA901798024/CCAPI/ccCallSetupRequest:exit@2726
Aug 29 12:03:56.131: //21/DBA901798024/CCAPI/ccCallSetContext:
   Context=0x318D3A1C
Aug 29 12:03:56.131: //20/DBA901798024/CCAPI/ccSaveDialpeerTag:
Aug 29 12:03:56.131: //21/DBA901798024/CCAPI/cc_find_feature_vsa:
Aug 29 12:03:56.131: //20/DBA901798024/CCAPI/ccCallGetContext:
   Context=0x2BDEA588, Call Id=20
Aug 29 12:03:56.131: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data:
   data_mode=0x10082
Aug 29 12:03:56.131: //-1/xxxxxxxxxxxx/CCAPI/cc_api_faxcap_to_bitrate:
   CALL_ERROR_INFORMATIONAL; Fax Cap Is Invalid; Fax Cap=0
Aug 29 12:03:56.131: //21/DBA901798024/CCAPI/cc_api_insert_call_active_entry:
Aug 29 12:03:56.131: //21/DBA901798024/CCAPI/cc_incr_if_call_volume:
   Remote IP Address
   Total Call Count=1, Voip Call Count=1, MMoip Call Count=0
Aug 29 12:03:56.139: //21/DBA901798024/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Aug 29 12:03:56.139: //21/DBA901798024/CCAPI/cc_api_call_proceeding:
   Interface=0x3106291C, Progress Indication=NULL(0)
Aug 29 12:03:56.139: //21/DBA901798024/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
Aug 29 12:03:56.139: //21/DBA901798024/CCAPI/cc_api_call_cut_progress:
   Interface=0x3106291C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=1
Aug 29 12:03:56.143: //21/DBA901798024/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
Aug 29 12:03:56.143: //20/DBA901798024/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=1
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Aug 29 12:03:56.143: //20/DBA901798024/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=20
Aug 29 12:03:56.143: //20/DBA901798024/CCAPI/ccConferenceCreate:
   (confID=0x30C4883C, callID1=0x14, gcid=DBA90179-4D7C11E5-8024BB6D-126A5FF8, tag=0x0)
Aug 29 12:03:56.143: //21/DBA901798024/CCAPI/ccConferenceCreate:
   (confID=0x30C4883C, callID2=0x15, gcid=DBA90179-4D7C11E5-8024BB6D-126A5FF8, tag=0x0)
   Conference Id=0x30C4883C, Call Id1=20, Call Id2=21, Tag=0x0
Aug 29 12:03:56.143: //20/DBA901798024/CCAPI/cc_api_bridge_done:
   Conference Id=0xC, Source Interface=0x2CDFFBD4, Source Call Id=20,
   Destination Call Id=21, Disposition=0x0, Tag=0xFFFFFFFF
Aug 29 12:03:56.143: //21/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 29 12:03:56.143: cc_api_get_xcode_stream : 4803
Aug 29 12:03:56.143: //21/DBA901798024/CCAPI/cc_api_get_xcode_stream:
Aug 29 12:03:56.143: //21/DBA901798024/CCAPI/cc_api_bridge_done:
   Conference Id=0xC, Source Interface=0x3106291C, Source Call Id=21,
   Destination Call Id=20, Disposition=0x0, Tag=0x0
Aug 29 12:03:56.143: //20/DBA901798024/CCAPI/cc_generic_bridge_done:
Aug 29 12:03:56.143: //-1/xxxxxxxxxxxx/CCAPI/cc_exchange_calls_mlpp_info:
   Unable too Get MLPP nformation for callID 20
   Call Entry(Conference Id=0xC, Destination Call Id=21)
   Call Entry(Conference Id=0xC, Destination Call Id=20)
Aug 29 12:03:56.143: //20/DBA901798024/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3106291C, Destination Call Id=21, Source Call Id=20,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Aug 29 12:03:56.143: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=599212133, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=599212133
Aug 29 12:03:56.143: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 29 12:03:56.143: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
     2: Dial-peer Tag=12
   Result=SUCCESS(0)
     1: Dial-peer Tag=14
     2: Dial-peer Tag=13
Aug 29 12:03:56.143: //20/DBA901798024/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xC, Call Id1=20, Call Id2=21
Aug 29 12:03:56.151: //21/DBA901798024/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2CDFFBD4, Destination Call Id=20, Source Call Id=21,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
Aug 29 12:03:56.151: //21/DBA901798024/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=255)
Aug 29 12:03:56.151: //20/DBA901798024/CCAPI/cc_api_caps_ack:
Aug 29 12:03:56.151: //20/DBA901798024/CCAPI/cc_api_voice_mode_event:
   Call Id=20
   Call Entry(Context=0x318EBD3C)
Aug 29 12:03:57.419: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:03:58.691: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:03:59.963: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:01.231: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:02.499: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:03.771: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:05.043: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:06.311: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:07.583: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:08.851: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:10.123: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:11.391: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:12.663: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:13.931: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:14.043: //21/DBA901798024/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x3106291C, Call Id=21
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Aug 29 12:04:14.043: //20/DBA901798024/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Aug 29 12:04:14.043: //21/DBA901798024/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=21
Aug 29 12:04:14.043: //20/DBA901798024/CCAPI/ccConferenceDestroy:
   Conference Id=0xC, Tag=0x0
Aug 29 12:04:14.043: //20/DBA901798024/CCAPI/cc_detect_mute_call:exit@934
Aug 29 12:04:14.043: //-1/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
   CALL_ERROR_INFORMATIONAL; mute call detection failed with confID=0xC
Aug 29 12:04:14.043: //20/DBA901798024/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=21, Disposition=0x0, Tag=0x0
Aug 29 12:04:14.043: //21/DBA901798024/CCAPI/cc_api_bridge_drop_done:
Aug 29 12:04:14.043: //20/DBA901798024/CCAPI/cc_generic_bridge_done:
Aug 29 12:04:14.043: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
Aug 29 12:04:14.043: //21/DBA901798024/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Disconnect Cause=1)
Aug 29 12:04:14.047: //21/DBA901798024/CCAPI/ccCallDisconnect:
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Aug 29 12:04:14.047: //21/DBA901798024/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Aug 29 12:04:14.047: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:14.055: //21/DBA901798024/CCAPI/cc_api_get_transfer_info:
Aug 29 12:04:14.055: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif:
   ExpectFactor=0xA
Aug 29 12:04:14.055: //21/DBA901798024/CCAPI/cc_api_insert_call_history:
Aug 29 12:04:14.055: //21/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Aug 29 12:04:14.055: //21/DBA901798024/CCAPI/cc_decr_if_call_volume:
   Remote IP Address
   Total Call Count=0, Voip Call Count=0, MMoip Call Count=0
Aug 29 12:04:14.055: //21/DBA901798024/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3106291C, Tag=0x0, Call Id=21,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Aug 29 12:04:14.055: //21/DBA901798024/CCAPI/cc_disconnect_notify:
Aug 29 12:04:14.059: //21/DBA901798024/CCAPI/callStackPop:exit@4930
Aug 29 12:04:14.059: //21/DBA901798024/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
Aug 29 12:04:14.059: //21/DBA901798024/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
Aug 29 12:04:14.059: //21/DBA901798024/CCAPI/cc_delete_guid_pod_entry:exit@1183
Aug 29 12:04:14.059: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 29 12:04:14.059: :cc_free_feature_vsa freeing 2BD65F40
Aug 29 12:04:14.059:  vsacount in free is 1
Aug 29 12:04:14.059: //21/DBA901798024/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x31879354]
Aug 29 12:04:14.059: //21/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   Call Entry Is Not Found
Aug 29 12:04:14.059: //-1/xxxxxxxxxxxx/CCAPI/ccGetCallGCID:
   CALL_ERROR_INFORMATIONAL; Call Entry Is Not Found
Aug 29 12:04:14.059: //-1/xxxxxxxxxxxx/CCAPI/ccSetCallGCID:
Aug 29 12:04:14.059: //20/DBA901798024/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=13, Params=0x318D4ECC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Aug 29 12:04:14.059: //20/DBA901798024/CCAPI/ccCheckClipClir:
   Guid=DBA90179-4D7C-11E5-8024-BB6D126A5FF8, Outgoing Dial-peer=13
Aug 29 12:04:14.059: //20/DBA901798024/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=599212133
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=0
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   final_
KP1-S9-VG1#
KP1-S9-VG1#redirectNumber =
Aug 29 12:04:14.059: //20/DBA901798024/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=13, Call Count On=FALSE,
Aug 29 12:04:14.059: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 29 12:04:14.059: :cc_get_feature_vsa malloc success
Aug 29 12:04:14.059:  cc_get_feature_vsa count is 2
Aug 29 12:04:14.059: :FEATURE_VSA attributes are: feature_name:0,feature_time:735469384,feature_id:22
Aug 29 12:04:14.059: //22/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
Aug 29 12:04:14.059: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
Aug 29 12:04:14.059:  call_init_entry calle is 2BD5FEA8,callid is 22
Aug 29 12:04:14.059: //22/DBA901798024/CCAPI/cc_init_call_entry:
Aug 29 12:04:14.059: //20/DBA901798024/CCAPI/cc_peer_bind:
   Bind=TRUE, Binder Call Id=20, Bindee Call Id=22
Aug 29 12:04:14.059: //22/DBA901798024/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=22
Aug 29 12:04:14.059: //22/DBA901798024/CCAPI/cc_set_voice_port_value:exit@2153
Aug 29 12:04:14.059: //20/DBA901798024/CCAPI/ccIsCallConnectedByHandler:
Aug 29 12:04:14.059: //22/DBA901798024/CCAPI/ccIFCallSetupRequestPrivate:
Aug 29 12:04:14.059: //20/DBA901798024/CCAPI/ccCallSetupRequest:exit@2726
Aug 29 12:04:14.059: //22/DBA901798024/CCAPI/ccCallSetContext:
   Context=0x318D4E7C
Aug 29 12:04:14.059: //20/DBA901798024/CCAPI/ccSaveDialpeerTag:
Aug 29 12:04:14.059: //22/DBA901798024/CCAPI/cc_find_feature_vsa:
Aug 29 12:04:14.059: //20/DBA901798024/CCAPI/ccCallGetContext:
   Context=0x2BDEA9D8, Call Id=20
Aug 29 12:04:14.059: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
Aug 29 12:04:14.059: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
Aug 29 12:04:14.059: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data:
   data_mode=0x10082
Aug 29 12:04:14.059: //-1/xxxxxxxxxxxx/CCAPI/cc_api_faxcap_to_bitrate:
Aug 29 12:04:14.063: //22/DBA901798024/CCAPI/cc_api_insert_call_active_entry:
Aug 29 12:04:14.063: //22/DBA901798024/CCAPI/cc_incr_if_call_volume:
   Remote IP Address
Aug 29 12:04:14.375: //22/DBA901798024/CCAPI/cc_api_set_called_ccm_detected:
Aug 29 12:04:14.375: //22/DBA901798024/CCAPI/cc_api_call_proceeding:
Aug 29 12:04:14.379: //22/DBA901798024/CCAPI/ccIsInfoRingback:
Aug 29 12:04:14.379: //22/DBA901798024/CCAPI/cc_api_call_cut_progress:
   Cause Value=1
Aug 29 12:04:14.379: //20/DBA901798024/CCAPI/ccCallCutProgress:
Aug 29 12:04:14.379: //20/DBA901798024/CCAPI/ccGenerateToneInfo:
Aug 29 12:04:14.379: //20/DBA901798024/CCAPI/ccConferenceCreate:
   (confID=0x30C48884, callID1=0x14, gcid=DBA90179-4D7C11E5-8024BB6D-126A5FF8, tag=0x0)
Aug 29 12:04:14.379: //22/DBA901798024/CCAPI/ccConferenceCreate:
   (confID=0x30C48884, callID2=0x16, gcid=DBA90179-4D7C11E5-8024BB6D-126A5FF8, tag=0x0)
   Conference Id=0x30C48884, Call Id1=20, Call Id2=22, Tag=0x0
Aug 29 12:04:14.379: //20/DBA901798024/CCAPI/cc_api_bridge_done:
   Conference Id=0xD, Source Interface=0x2CDFFBD4, Source Call Id=20,
   Destination Call Id=22, Disposition=0x0, Tag=0xFFFFFFFF
Aug 29 12:04:14.379: //22/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 29 12:04:14.379: cc_api_get_xcode_stream : 4803
Aug 29 12:04:14.379: //22/DBA901798024/CCAPI/cc_api_get_xcode_stream:
Aug 29 12:04:14.379: //22/DBA901798024/CCAPI/cc_api_bridge_done:
   Conference Id=0xD, Source Interface=0x3106291C, Source Call Id=22,
Aug 29 12:04:14.379: //20/DBA901798024/CCAPI/cc_generic_bridge_done:
Aug 29 12:04:14.379: //-1/xxxxxxxxxxxx/CCAPI/cc_exchange_calls_mlpp_info:
   Call Entry(Conference Id=0xD, Destination Call Id=22)
   Call Entry(Conference Id=0xD, Destination Call Id=20)
Aug 29 12:04:14.379: //20/DBA901798024/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3106291C, Destination Call Id=22, Source Call Id=20,
Aug 29 12:04:14.379: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Succ
KP1-S9-VG1#ess(0) after DP_MATCH_DEST
Aug 29 12:04:14.379: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 29 12:04:14.379: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
     2: Dial-peer Tag=12
   Result=SUCCESS(0)
     1: Dial-peer Tag=14
     2: Dial-peer Tag=13
Aug 29 12:04:14.383: //20/DBA901798024/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xD, Call Id1=20, Call Id2=22
Aug 29 12:04:15.211: //22/DBA901798024/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2CDFFBD4, Destination Call Id=20, Source Call Id=22,
Aug 29 12:04:15.215: //22/DBA901798024/CCAPI/cc_api_caps_ind:
Aug 29 12:04:15.215: //22/DBA901798024/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=5329)
Aug 29 12:04:15.215: //20/DBA901798024/CCAPI/cc_api_caps_ack:
Aug 29 12:04:15.219: //20/DBA901798024/CCAPI/cc_api_voice_mode_event:
   Call Id=20
Aug 29 12:04:17.079: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
KP1-S9-VG1#
Aug 29 12:04:18.947: //20/DBA901798024/CCAPI/ccGetCallActiveByCallID:
Current configuration : 7344 bytes
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
trunk group PSTN
trunk group MOB
voice-card 0
 dsp services dspfarm
voice service pots
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol none
 h323
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711alaw
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
voice class dualtone-detect-params 1111
 freq-max-deviation 20
 cadence-variation 6
voice class custom-cptone voice
 dualtone disconnect
  frequency 450
  cadence 355 2095
control-plane
voice-port 0/0/0
 trunk-group PSTN
 supervisory disconnect dualtone mid-call
 supervisory custom-cptone voice
 supervisory dualtone-detect-params 1111
 no battery-reversal
 cptone BR
 timeouts call-disconnect 5
 timeouts ringing 5
 timeouts wait-release 5
 timing hookflash-out 50
 connection plar opx 0
 caller-id enable
 caller-id alerting line-reversal
 caller-id alerting dsp-pre-allocate
voice-port 0/0/1
 trunk-group PSTN
 no battery-reversal
 cptone BR
 timeouts ringing 5
 impedance complex2
 caller-id enable
voice-port 0/0/2
 trunk-group PSTN
 no battery-reversal
 cptone BR
 timeouts ringing 5
 impedance complex2
 caller-id enable
voice-port 0/0/3
 trunk-group PSTN
 no battery-reversal
 cptone BR
 timeouts ringing 5
 caller-id enable
mgcp profile default
dial-peer voice 1 pots
 trunkgroup PSTN
 destination-pattern 9[2-9]......
 forward-digits 7
dial-peer voice 2 pots
 trunkgroup PSTN
 destination-pattern 901[2346789].......
 forward-digits 10
dial-peer voice 3 pots
 trunkgroup PSTN
 destination-pattern 905........
 forward-digits 10
dial-peer voice 5 pots
 trunkgroup PSTN
 destination-pattern 9800.......
 prefix 800
dial-peer voice 6 pots
 trunkgroup PSTN
 destination-pattern 900T
 prefix 00
dial-peer voice 7 pots
 trunkgroup PSTN
 destination-pattern 99..
 prefix 9
dial-peer voice 11 voip
 description to PUB
 preference 1
 destination-pattern [2345678]..
 session target ipv4:10.209.115.1
 voice-class codec 1
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 12 voip
 description to SUB
 preference 2
 session target ipv4:10.209.115.2
 voice-class codec 1
 voice-class h323 1
 no vad
dial-peer voice 9 pots
 trunkgroup PSTN
 destination-pattern 99200.....
 prefix 9200
Your "connection plar opx 0" but I don't see any dial-peers with destination-pattern 0, I also don't see dial-peer 13 or 14, yet the debug is showing it matching.  Normally you do not want destination to be 0, as zero is not assigned as an extension, but typically simply a translation-patter on CUCM to point to something with real extension, in which case that is the extension you would point to. How is 0 defined in CUCM for you and please provide full config.
Sorry abt that the configuration was missing part of it by mistake
here u the full config of what i am allowed to give :
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
trunk group PSTN
trunk group MOB
voice-card 0
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
  ipv4 10.9.0.0 255.255.0.0
 fax protocol none
 h323
voice class codec 1
 codec preference 1 g711ulaw
voice class h323 1
 cadence-variation 6
 dualtone disconnect
  frequency 450
  cadence 355 1995
license udi pid CISCO2911/K9 sn FCZ16337L0T
hw-module pvdm 0/0
redundancy
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
 trunk-group PSTN
 no battery-reversal
 cptone BR
 timeouts ringing 5
 caller-id enable
voice-port 0/0/1
 trunk-group PSTN
 no battery-reversal
 cptone BR
 timeouts ringing 5
 impedance complex2
 caller-id enable
voice-port 0/0/2
 trunk-group PSTN
 no battery-reversal
 cptone BR
 timeouts ringing 5
 impedance complex2
 caller-id enable
voice-port 0/0/3
 trunk-group PSTN
 no battery-reversal
 cptone BR
 timeouts ringing 5
 caller-id enable
 trunkgroup PSTN
 forward-digits 7
 trunkgroup PSTN
 forward-digits 10
 trunkgroup PSTN
 forward-digits 10
 trunkgroup PSTN
 prefix 800
 trunkgroup PSTN
 prefix 00
 trunkgroup PSTN
 prefix 9
 description to PUB
 preference 1
 session target ipv4:10.9.115.1
 voice-class codec 1
 voice-class h323 1
 no vad
 description to SUB
 preference 2
 session target ipv4:10.9.115.2
 voice-class codec 1
 voice-class h323 1
 no vad
 trunkgroup PSTN
 prefix 9200
dial-peer voice 14 voip
 description to PUB
 preference 1
 voice-class codec 1
 voice-class h323 1
 no vad
dial-peer voice 13 voip
 description to SUB
 preference 2
 voice-class codec 1
 voice-class h323 1
 no vad
gatekeeper
 shutdown
How is pattern "0" defined in CUCM? is it in partition that is listed in the CSS assigned to the H323 GW?
it's registered with CUCM as extension ..
as 0 will be the operator ..
Please advice
Thank u very much it was CSS Problem i changed the H.323 CSS and it works.
I have another issue that i have 3 analog lines connected to the fxo voice ports
all outgoing calls are pass through one line .
what i need is to associate a single IP Phone with a specific FXO line that when it calls out have to use the line i specified to .
Please advice
Easiest solution would be to put all 3 in the same trunk-group and point the pots dial peers to the trunk group, this would share all 3 lines for all phones.
If you need dedicated line per phone there are few ways to do this all depending on version of IOS you are using, the easiest one would be to prefix different number(s) as IP phones make calls to the beginning of dialed number and then simply match dedicated dial-peer and strip the leading digits.
I am already using Trunk-group for these lines.
but there is a manager phone want to use one line by himself only
i am using 15.1 IOS.
Can u please tell me how to do it Step by Step Please ?!
your quick reply is highly appreciated.
