Route Outside Calls to SIP Endpoint
Randy Calderon
Hello Experts,
We use CUCM 10.5 with H.323 gateways. I've create a SIP Trunk, SIP Profile, and SIP Security Profile according to the vendors specifications. But now, I need to route outside calls to a SIP endpoint (a server running the IVR application). I do not know how to do that and I'd like to request some guidance from anyone that is knowledgeable with SIPs.
Thank you,
Randy C.
saif musa
Level 4
Level 4
following steps according to cucm v8. On your version it might be some differences.
1- add your IVR server as sip gateway inside cucm
      Device > trunk > add new
2- route calls to that sip gateway which you allready configured in step 1
     Call route > routehunt > route pattern > add new
      Don't forget to select your sip server from gateway selection bar
Please rate if it's helpful
