SRST Incoming is not working getting issue destination out of order
We have configured SRST at Remote branch.
Please find configuration.
Please let me know if is there any changes in this configuration.
I have one question should i create dial-peer for incoming call.
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.108.20.6 port 2000
max-ephones 50
max-dn 50
system message primary SRST Active
keepalive 20
ccm-manager fallback-mgcp
application
global
service alternate default
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0/0
  bind media source-interface GigabitEthernet0/0/0
  registrar server expires max 1200 min 60
voice class codec 1
  codec preference 1 g711ulaw
  codec preference 2 g711alaw
  codec preference 3 g729r8
voice register global
esrst
timeouts interdigit 5
system message "SRST Mode"
max-dn 50
max-pool 50
voice register pool  1
id network 10.108.22.0 mask 255.255.255.0
no digit collect kpml
voice-class codec 1
voice translation-rule 1
rule 1 /^62726\(6..\)$/ /6\1/
voice translation-rule 2
rule 1 /^62726\(5..\)$/ /6\1/
voice translation-profile SRST1
translate called 1
voice translation-profile SRST2
translate called 2
voice-port 0/1/0:15
translation-profile incoming SRST1
voice-port 0/1/1:15
translation-profile incoming SRST2
DID range =627266XX
dial-peer voice 11 pots
description "SRST_LOCAL_MOB_CALLS"
incoming called-number 66..
destination-pattern 9[7-9].........
port 0/1/0:15
forward-digits 10
dial-peer voice 12 pots
description "SRST_LOCALCAllS"
destination-pattern 9[1-7].......
port 0/1/0:15
forward-digits 8
dial-peer voice 13 pots
description "SRST_STDCALLS"
destination-pattern 90[0-9].........
port 0/1/0:15
forward-digits 11
dial-peer voice 14 pots
description "SRST_ISDCALL"
destination-pattern 900T
port 0/1/0:15
prefix 00
DID range =627265XX
dial-peer voice 1 pots
incoming called-number 65..
port 0/1/1:15
forward-digits 10
dial-peer voice 2 pots
port 0/1/1:15
forward-digits 8
dial-peer voice 3 pots
port 0/1/1:15
forward-digits 11
dial-peer voice 4 pots
port 0/1/0:15
prefix 00
use de following debug and send the log please:
debug voice ccapi inout
Best regards,
Marcelo Morais
the incoming called-number command is one of the responsible for the dial-peer incoming calls, to make the dial-peer more clear you can remove all the incoming called-number commands and insert the following lines:
dial-peer voice 66 pots
description "SRST_INCOMING_FROM_PSTN 0/1/0"
direct-inward-dial
port 0/1/0:15
dial-peer voice 65 pots
description "SRST_INCOMING_FROM_PSTN 0/1/1"
direct-inward-dial
port 0/1/1:15
Hope this helps,
Marcelo Morais
Hi Marcelo,
I have configured this but getting issue
Cause i = 0x8292 - No user responding
Best regards,
Marcelo Morais
