SRSV and VPIM EoL Notice for Unified Messaging Gateway (UMG)
karmakar
End of life notices for VPIM and SRSV features on UMG (Unified Messaging Gateway)
We would like to announce the transition plan and end of life milestones for two features on the Unified Messaging Gateway (UMG) product. These changes affect Cisco’s overall voice mail solution delivery.
Features affected –
  • VPIM – Voice Profile for Internet Mail
  • SRSV – Survivable Remote Site Voicemail
VPIM was part of UMG 1.0, and was designed to be a central hub in a large voice mail messaging network. Over time, the critical VPIM features were absorbed into Cisco Unity Connection (CUC) and Cisco Unity Express (CUE). While CUC and CUE are not direct replacements for the UMG-VPIM feature set, they can directly interact with other VPIM-compatible messaging products. Our recommendation is to use either CUC or CUE for VPIM interoperability.
SRSV was introduced in UMG 8.0, and was our solution for voice mail survivability. During WAN failures, SRSV provided local voice mail and auto-attendant capabilities, and later seamlessly synchronized the voice messages to the central site.
We are transitioning the SRSV survivability and synchronization features from UMG and SRSV modules directly to Unity Connection. This will help us in several ways –
  1. Feature compatibility during WAN up and down state,
  2. Eliminating the need for a dedicated ISR-SRE module at the central site,
  3. Fewer components and thus simplified management of the solution.
Additionally, to resemble the current SRSV branch hardware footprint, this flavor of Unity Connection will be supported on the SRE.
The key dates are –
  1. External announcement – Today.
  2. End of sale – June 18, 2012
  3. End of maintenance releases – June 18, 2013
  4. End of support – June 30, 2015
For questions and clarifications, contact your Cisco sales representatives or this forum.
Cisco Voice Messaging Team.
Product home pages –
  1. UMG – http://www.cisco.com/go/umg
  2. CUC – http://www.cisco.com/go/cuc
  3. CUE – http://www.cisco.com/go/cue
12 Replies 12
mcasimirc63
Level 4
Level 4
That was quick!
http://communities.cisco.com/thread/18504
When will CUC come out with the SRSV feature?
Our current target is 2nd half of Calendar year 2012.  But, like all targets, this is subject to change ;-)
Brent Rindal - Cisco Unity Connection Product Manager
Is there any information that can be shared on architectures, licensing? If the UMG is eliminated where does the license now move?
Srini
UMG wouldn't be eliminated - you will still need it for SRST.
We are still working out some of the architectual/design considerations, but for licensing, we will likely license it on the home Unity Connection server (centralized Connection server), or alternatively the enterprise license manager server.
skilambi
On a side note the comments above were specific to SRSV, how does this impact E-SRST. Since that functionality is not relevant to Uconn, how will that propogate?
Srini
E-SRST will continue to use UMG for provisioning enhanced SRST functionality on the router today.
We are virtualizing the E-SRST software ( roadmap item) which will enable you to host the E-SRST software on any UCS server or UCS express blade
Mili
Any updates on the replacement for SRSV?
Believe the replacement for SRSV is coming in Nov 2012 or latest early 2013
https://communities.cisco.com/message/105761#105761
**this URL is accessible only to Collaboration User Group members. You can join the User Group here: https://communities.cisco.com/community/technology/collaboration/usergroups**
Beta for 9.1 with Native SRSV to start soon.
Message was edited by: Kelli Glass
Is anyone having any design doc for Native SRSV ? If so please share this.
Hi Arun,
I you send me an email (brindal@cisco.com) I will send you back a draft copy of the design guide.  The release version should be posted as well by the end of the week.
-Brent
Hi Brinda
Thanks for your response. Could you please send me draft copy of the design guide on my this email, it would be very helpful to evaluate this version and include this version into our upcoming projects.
thanks in advance..
Arun Sharma (WT01 - HLS)
