Room Bar - MS Teams Room with access to CMS and Zoom calls
luke.maxwell
I am looking to see if its possible to have a Room Bar using the MTR function but retain access to be able to join local CMS meetings and remote Zoom meetings. The device is CUCM registered and not WCH. I can't see anything covering on premise devices in the documentation but I did hear on prem MTR is supported somewhere.
https://roomos.cisco.com/doc/MTR
Limitation is there is no Calendar integration so OBTP is not an option hence I am looking at MTR as an option. Is it easy/possible to switch a device between RoomOS and MTR?
We looked at deploying a button onto the Navigator for 3rd party meetings, but you have to pre code the MS teams tenant so limits calls to a single MS instance and we need to support joining 3rd party MS tenants, Zoom calls and local CMS.
afadeyev1
"We looked at deploying a button onto the Navigator for 3rd party meetings, but you have to pre code the MS teams tenant". How do you do that? Have a link for the doc by any chance?
