Webex Whiteboard Drawing API
matt.storr1
Is there any way for me to provide external drawing input into the whiteboard application in Webex so I can draw and annotate using (for example) an electronic stylus.  I find trying to draw with the mouse quite hard and ideally would like to interface an external drawing tool into the Whiteboard app so I can use that to draw on the screen with.
Thanks.
nmorrow
     Our technical support team is best equipped to answer questions about supported input methods for the whiteboard. You may also find input support information at support.webex.com.
Hello Nathan,
Is there a specific answer for this question? I am unable to locate anything specific at support.webex.com
Thank you,
Sundar
