06-28-2018 07:01 PM - edited 03-05-2019 10:41 AM
My company's Corporate office in Calgary, Alberta is switching ISP providers, which means we will need to configure the new global IP address for the Corporate office. The only problem is, I'm the only IT guy and I work out of Calgary. We have two branch offices, one in Leduc, Alberta, and one in Phoenix, Arizona. How could I go about changing the IP address on the Leduc and Phoenix Firewalls without physical being there? Once that global IP address is changed, I will lose connection to the other 2 firewalls.
Any suggestions on how this could be done would be much appreciated! And if you need any more information, let me know.
Thank you
Brad
Solved! Go to Solution.
06-30-2018 09:57 AM
06-28-2018 08:46 PM
Before answering, can you tell if you will have both provider running in parallel for few days?
06-29-2018 03:57 PM
So I asked the CEO if they were going to be running both providers parallel for a few days, as I just started with this company 2 weeks ago, and they told me yesterday they wanted to change providers. He said it was up to me. I did tell him how if we just switched to the other provider and cut off the current provider right at the same time the vpn tunnel would go down.
So, I think I might know where you going with this, and would that be to configure two tunnels? Using ssh to connect to the Leduc, and Phoenix ASA on the tunnel 1 and configuring a 2nd tunnel?
06-30-2018 09:57 AM
06-30-2018 10:27 AM
Thank you for the help. This is my first job in IT, so I really appreciate your advice. I don't know if I would have thought of running both providers parallel for a few day's.
I can SSH in remotely to both site's, so that's what I'll do.
Thanks again,
Brad
07-01-2018 11:45 PM
07-02-2018 02:56 PM
Thanks, appreciated. it helped me out also.
