887V and BGP
PATRICK DUPONT
Hello All,
I need help i have a  887V and put this IOS:lash:c880data-universalk9-mz.150-1.M1.bin which in the Cisco Feature Navigator
which says it that my IOS should have Advanced IP and supports BGP, now the issue i am having is when i want to use the BGP is is not in the list, What am i missing here?
Example Below:
887V(config)#router ?
  odr  On Demand stub Routes
  rip  Routing Information Protocol (RIP)
887V uptime is 1 minute
System returned to ROM by reload at 13:46:51 UTC Thu Feb 10 2011
System image file is "flash:c880data-universalk9-mz.150-1.M1.bin"
Last reload reason: Reload Command
3 Accepted Solutions
It is perhaps necessary to purchase and activate a specific feature license on your router to unlock the BGP capability. Can you verify your current licenses using the show license feature and show license all commands?
Best regards,
Peter
Feature name             Enforcement  Evaluation  Subscription   Enabled
advipservices               yes                  yes                no                     no
Srry i have never seen this before?
It's OK.  That's what we are here for.
Ok so how do i enbale it???
The new ISR G2's have software license activation.  You'll need to contact the authorized Cisco reseller and purchase the license key to activate the feature set of your choice.
Cisco IOS Software Packaging and Licensing
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-579326_ps10745_Products_White_Paper.html
Thanks for the ratings.
6 Replies 6
PATRICK DUPONT
Anybody have an answer for this issue i am having with my 887V?
Best regards,
Peter
Thanxs alot for answering my post,
Here is an output of the commands u asked for:
887V#sh license fea
887V#sh license feature
advsecurity              no           no          no             yes
ios-ips-update           yes          no          yes            no
SSL_VPN                  yes          yes         no             no
887V#sh licen
887V#sh license all
License Store: Primary License Storage
StoreIndex: 0   Feature: advsecurity                       Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
License Store: Evaluation License Storage
StoreIndex: 0   Feature: advipservices                     Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
        License Priority: None
StoreIndex: 1   Feature: SSL_VPN                           Version: 1.0
        License Count: 10/0/0  (Active/In-use/Violation)
sh Ver:
887V#sh ver
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 02-Dec-09 18:48 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
887V uptime is 8 minutes
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 887VDSL2 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FHK1415724T
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
1 ISDN Basic Rate interface
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO887V-K9          FHK1415724T
License Information for 'c880-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
Ok so how do i enbale it??? Srry i have never seen this before?
