Web services and IPPS on 8945 Ip Phone
droutledge
When sending a message to the 8945 phone with CUCM 10.x firmware on it, the message shows up after approximately 2 minutes.  The phone log shows some sort of internal phone error.
springboard: _g_cgi_exec_list_wait_node_done()@125 cond timeout
Can you please escalate and fix this asap.  The quality of the firmware and function on the newer Cisco phones is well below the standard the 79xx set, and not acceptable in the business world.
Geevarghese Cheria
Hi Doug,
Sorry for the delay in responding to you. On searching our knowledge database could find a similar issue were
it appears to be a firmware issue. Can you please try using the following firmware  SCCP8941_8945.9-3-2-11
I belive your 8945 is running on SCCP.
Thanks and Regards,
Geevarghese
