Jtapi transfers
punin.v.v
Hi there
I'm having a big trouble with transfers and JTAPI:
In our company we named this scenarion single-step transfer
Step 1:
Connect via jtapi to cucm
Register CallObserver, AddresObserver, TerminalObserver for extension A, extension B
But not register Observers for extension C
All events from CUCM are loged
Step 2:
A make outgoing call to B
B answer
B press key "transfer" and enter extension C
C doesn't answer
B press key "transfer" second time and redirect incoming call from A to C
C answer  <- at this moment i haven't any events from CUCM. Should be there any events, or not?
C end call - all is fine
With best regards,
Punin Viktor
pmnkumar
Since 'A' is already in its final state (TALKING) before transfer there is no state change on A side and no events are expected.  Since there is no observer on C you will most likely end up with a 'alerting' connection for C.
You will have to use the RTP events to check if the call is answered.
