Retrieve Terminal Description from CTI event
mencarnacion
Hi Everyone,
Is there a way to actually retrieve the terminal description from a Terminal event?
I can get the called / calling address display name by getCalledPartyInfo().
But what I'm interested in is the actual information of the Terminal.
Description: Lab MyTerminal
Is there a way to get that value?
Thank you.
Hi Mohan,
I've managed to execute SOAP request to AXL.
private static void directQuery() throws IOException {
System.setProperty("javax.net.ssl.trustStore", "C:/glassfish3/glassfish/domains/domain1/config/cacerts.jks");
System.setProperty("javax.net.ssl.trustStorePassword", "changeit");
InetAddress addr = InetAddress.getByName("192.168.9.12");
String host = addr.getHostName();
System.out.println("TEST += " + host);
URL url = new URL("https://" + host + ":8443/axl/");
URLConnection conn = url.openConnection();
conn.setDoOutput(true);
String authorization = "user:pass";
String encoding = Base64.encode(authorization.getBytes("UTF-8"));
conn.setRequestProperty("Authorization", "Basic " + encoding);
String version = "10.0";
conn.setRequestProperty("SOAPAction", "\"CUCM:DB ver=" + version + " getPhone\"");
conn.setRequestProperty("Content-Type", "text/xml");
conn.setRequestProperty("Connection", "Keep-Alive");
// Create an OutputStreamWriter for the URLConnection object and make the request
OutputStreamWriter writer = new OutputStreamWriter(conn.getOutputStream());
System.out.println("1 - THIS CURRENT TIME " + System.currentTimeMillis());
String AXLRequest = "<soapenv:Envelope xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:ns=\"http://www.cisco.com/AXL/API/" + version + "\">";
AXLRequest += "<soapenv:Body><ns:getPhone><name>SEP000C30527EAF</name></ns:getPhone></SOAP-ENV:Envelope>";
writer.write(AXLRequest);
// writer.write(AXLRequest);
writer.flush();
// Read the response
BufferedReader reader = new BufferedReader(new InputStreamReader(conn.getInputStream()));
// Output the response to the console;
String line;
String response ="";
while ((line = reader.readLine()) != null) {
System.out.println(line);
response += line;
System.out.println("2 - THIS CURRENT TIME " + System.currentTimeMillis());
writer.close();
reader.close();
parseSOAPDeviceResponse(response);
mpotluri
Level 5
Level 5
No Cisco JTAPI doesn't have or expose this information. You probably need to use AXL interface.
Hi Mohan,
Could you show me some sample code as to how to do that?
I'm using CUCM 9.1
Thank you.
Hi Mohan,
writer.flush();
String line;
response += line;
writer.close();
reader.close();
