getting a list of registered devices from spark control hub
apologies if this is a basic question but I have been unable to find an answer.
is there a Spark API call that allows me to retrieve the list of properties (user name, device URI etc) for each device registered with Spark Control Hub?
thanks
Mike
keglass
Level 7
Level 7
Mike,
Check out these documents for more information on device management:
Device Management | Cisco Cloud Collaboration Help Central
https://www.cisco.com/c/dam/en/us/solutions/collaboration/spark-control-hub.pdf
Kelli Glass
Moderator for Cisco Customer Communities
Hi Kelli
thanks. I read thru those and the only reference I can find is this:
table 1, page 9:
User and device management
Users can be onboarded (Invite flow using UI, CSV, DirSync, APIs, Convert Users flow) and managed. Licenses and entitlements for all Cisco Spark services, as well as roles for users, can be managed through Cisco Spark Control Hub.
The "user and device management" header suggests it can be done but the body text then says "users can be onboarded"; there is no reference to how to get details for all the devices registered with the hub via an API method.
So, what I'm really looking for is where to find the API that lets me get the device data from the hub.
thanks
Mike
Mike,
Have you visited the Cisco DevNet Community? That might be a good place to look for more information about available API's or the ability to create your own.
https://developer.cisco.com/site/collaboration/
Also, you can chat directly with the tech team via their Cisco Spark room:
https://developer.cisco.com/site/spark-chat/
