Record Element Delay
Joe Gilbert
I have a standard record element that works normally most of the time. In about 2/40 instances, the record element does not start recording until DTMF is pressed. I didn't think this was necessary. Is there something I have misconfigured?
First case (the initial audio group didn't play until 16 minutes later)
08/24/2016 23:45:22.873,wsLookup,exit,Success
08/24/2016 23:45:22.873,Record_Prompt,enter,
08/25/2016 00:01:44.578,Record_Prompt,interaction,audio_group,initial_audio_group
08/25/2016 00:02:03.441,Record_Prompt,data,duration,14670
08/25/2016 00:02:03.441,Record_Prompt,data,size,116720
08/25/2016 00:02:03.441,Record_Prompt,data,termchar,1
08/25/2016 00:02:03.441,Record_Prompt,data,maxtime,false
08/25/2016 00:02:03.441,Record_Prompt,data,filename,2016824-2345.wav
08/25/2016 00:02:03.441,Record_Prompt,data,filepath,C:\2016824-2345.wav
08/25/2016 00:02:03.441,Record_Prompt,exit,done
08/25/2016 00:02:03.441,smb_copy,enter,
Second case (the initital audio group plays twice with 18 minutes of silence in between)
09/02/2016 10:01:37.098,wsLookup,exit,Success
09/02/2016 10:01:37.098,Record_Prompt,enter,
09/02/2016 10:01:37.098,Record_Prompt,interaction,audio_group,initial_audio_group
09/02/2016 10:19:38.702,Record_Prompt,interaction,audio_group,initial_audio_group
09/02/2016 10:19:45.229,Record_Prompt,data,duration,2180
09/02/2016 10:19:45.229,Record_Prompt,data,size,16800
09/02/2016 10:19:45.229,Record_Prompt,data,termchar,1
09/02/2016 10:19:45.229,Record_Prompt,data,maxtime,false
09/02/2016 10:19:45.229,Record_Prompt,data,filename,201692-101.wav
09/02/2016 10:19:45.229,Record_Prompt,data,filepath,C:\201692-101.wav
09/02/2016 10:19:45.229,Record_Prompt,exit,done
09/02/2016 10:19:45.229,smb_copy,enter,
8 Replies 8
janinegraves
1. Pressing a dtmf should not be required to start the recording. Are
you sure you're not preceding this element with something that's waiting
for input?
2. Can you post the Settings and Audio tab of the Voice element just
prior to the WS element?
How long is the audio that is played in the Voice Element just prior to
the WS element?
And have you configured the VXML Property Name: fetchtimeout Value: 10s
(or some amount of time for the WS to complete)?
3. These might be relevant because Audio elements are non-blocking (they
play asynchronously) - so the gateway ALWAYS returns immediately (15ms)
and the app moves forward. However, once you're waiting for caller input
(like Record or Digits elements) the gateway MUST wait for all the
queued up audio to finish playing. That might be what you're experiencing...
3. The only times I've ever seen the Initial Audio Group play twice
without being marked as a NoInput or NoMatch is when it's in a
confirmation element and you've allowed the Reply:true option under
Settings and the caller either presses 3 (to trigger replay) or says the
word 'replay'.
Thank you for the reply, Janine.
1. The record element is preceded by a web service lookup which I would normally be suspicious of but in both cases it seems to finish successfully.
2. The voice element before the web service is a digits with confirmation. The various audio prompts played are between 5-10 seconds long. I do have the fecthtimeout set for 10 seconds in the project settings.
Are you aware that the FinalSilence setting doesn't work? The gateway doesn't detect silence when the caller finishes their recording. So the caller MUST press a DTMF tone to complete their recording. The only other way the system will stop recording, is when the allotted MaxTimeout or recording memory space configured on the gateway is full (ivr record memory session #kb). And in that case, the system assumes the recording was successful.
This may not sounds like your issue, but it might be worth ensuring that the Initial Prompt in your Record element SPECIFICALLY tells the caller to press a key to complete their recording.
Also, you've configured the Record element to allow up to 1800s of recording. Another customer recently found a gateway bug where the gateway can NOT take recordings longer than 17 minutes. That sounds awfully close to your 16 minute issue. I suspect it's the same issue.
Hope this helps.
I don't think I've explained the issue correctly. The issue is not that the recording is ending prematurely but the recording is not starting. I'll use my 2nd example from above.
At 10:01:37.098, the web service exits successfully and the initial audio plays to the caller. This audio says something like press 1 when the recording is complete. The caller is talking for the next 18 minutes and when he is done he presses 1 on the keypad. For some reason the initial audio is played again at 10:19:38.702. You can see the duration of the recording is only 2180ms. I pasted the record element's audio settings below.
can you post your gateway configuration - including space allotted for
ivr record...
VXML#sh run
Building configuration...
Current configuration : 10034 bytes
version 15.1
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname VXML
boot-start-marker
boot system flash c3900-universalk9-mz.SPA.151-4.M9.bin
boot-end-marker
logging buffered 16000
enable secret <omitted>
aaa new-model
aaa authentication login default group tacacs+ local enable
aaa authentication login no_tacacs enable
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization network default group tacacs+ local
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa accounting network default
group tacacs+
aaa accounting connection default
group tacacs+
aaa accounting system default
group tacacs+
aaa session-id common
clock timezone EST -5 0
clock summer-time EST recurring
no ipv6 cef
no ip source-route
ip cef
no ip domain lookup
ip domain name erieinsurance.com
ip host mediaserver-backup <omitted>
ip host mediaserver <omitted>
voice-card 0
voice service voip
no ip address trusted authenticate
sip
  rel1xx disable
  min-se 360 session-expires 360
  header-passing
voice translation-rule 1
rule 1 /<omitted>/ //
voice translation-profile block
translate called 1
http client cache memory pool 100000
http client cache memory file 600
http client connection timeout 60
http client response timeout 30
ivr prompt memory 15000
ivr record memory system 61440
ivr record memory session 15360
application
service new-call flash:bootstrap.vxml
  paramspace english index 0
  paramspace english language en
  paramspace english location flash
  paramspace english prefix en
service ringtone flash:ringtone.tcl
service cvperror flash:cvperror.tcl
service handoff flash:handoff.tcl
service bootstrap flash:bootstrap.tcl
  param sigdigits 7
vxml tree memory 1000
license udi pid C3900-SPE150/K9 sn <omitted>
license boot module c3900 technology-package uck9
redundancy
ip ssh time-out 60
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address <omitted>
no ip proxy-arp
duplex full
speed 1000
interface GigabitEthernet0/1
no ip address
no ip proxy-arp
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
no ip proxy-arp
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 <omitted>
logging facility local2
logging <omitted>
access-list 11 permit <omitted>
nls resp-timeout 1
cpd cr-id 1
tacacs-server host <omitted>
tacacs-server directed-request
tacacs-server key 7 <omitted>
control-plane
mgcp profile default
dial-peer voice <omitted> voip
description Required for CVP PM microapp
translation-profile incoming block
incoming called-number <omitted>
description CVP SIP ringtone
service ringtone
voice-class sip rel1xx disable
dtmf-relay rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
no vad
description CVP SIP error message
service cvperror
codec g711ulaw
no vad
description CVP VRU label
service bootstrap
codec g711ulaw
no vad
gatekeeper
shutdown
privilege exec level 15 configure
banner motd
line con 0
exec-timeout 5 0
password 7 <omitted>
login authentication no_tacacs
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 14 in
exec-timeout 3 0
transport input ssh
line vty 5 858
transport input ssh
scheduler allocate 20000 1000
ntp access-group peer 11
ntp server <omitted>
end
Hi Janine, I confirmed that I was running into bug CSCuw29082. I upgraded my VXML gateway to ios version 15.5(3)M3 and I no longer experience this issue. Thank you for your help on this one!
Thanks for letting me know. So can you now take recordings longer than
17min?
