Showing results forĀ
Search instead forĀ
Did you mean:Ā
switch-profile in nexus
siva prasad
I am new to switch-profile on nexus, I am getting below error commands on one of the 5k pair.
Error: Command is not mutually exclusive
I am able to remove and add commands to one box but not on the other, I would like to remove switch-profile,
what will be  the result of removing Switch-profile, does configuration will be lost?
let me know if any additional info required.
ruchik999
Hi Siva,
Nothing will happen if you break the peering. Config will remain same but you have to manually add config in future on both of the switches.
-thanks
ruchik
ruchik999
Hi Siva,
-thanks
ruchik
