Cisco 7925G and SHA-256
r.pennington
Level 5
Level 5
Are SHA-256 certs supported on the Cisco 7925G, we have them using SHA-1 today but need to update as these are being depreciated. The only guide I can find is from July 2015 which says SHA-2 is not supported, is that still the case, we will no longer be able to generate these certs.
Also is there anyway of getting the new certs on the phone other than sticking in the old USB cable.
Richard
viveky
Correct SHA-2 are not supported on 7925G version. New platforms will have improved functionality for cert management. Pls reach out to Cisco rep to get an update on these functionalities road map.
When you say new platforms ?? do you mean new Handsets ?
Does anyone know if this is on the roadmap for the 7925G and the details of when a new WIFI phone which will support this may be available ?
Pls reach out to your supporting Cisco account team and have a call with business unit on road map and upcoming releases.
