Custom Script Execution Error
chjaecke
Hi all,
I recently wanted to setup a custom service for CloudCenter and I run into the following problem that I wanted to share with you.
Unfortunately, I was not able to create such an External Service. I tried to create a really simple script which always failed:
Status Message
Failed to execute the script : /opt/remoteFiles/cliqr_local_file/service Status : 1
START
TaskRunning
11/03/17 15:55:00.123
Executing service START action with command: "/opt/remoteFiles/cliqr_local_file/service" from directory: /opt/remoteFiles/cliqr_local_file
START
TaskRunning
11/03/17 15:54:59.129
Downloading the script : https://raw.githubusercontent.com/***
START
TaskRunning
11/03/17 15:54:58.115
Cliqr execute script is : https://raw.githubusercontent.com/***
START
TaskRunning
11/03/17 15:54:57.127
Download service bundle: success.
I wrote the script on Windows. Since the script is executed on a Linux Docker container, I ran into issues with end of lines on Windows vs. Linux. As a solution, you can either use the Dos2Unix tool to convert the script from Windows to Unix encoding or you open the file in Notepad++ and change to Unix EOL: "Edit" > "EOL Conversion" > "Unix (LF")
Hope this information helps you not to run into the same problems as I had.
Christian
0 Replies 0
