Cisco catalyst 9200 Module Issue
tonyplueard
We have Catalyst C9200L-24P-4X. I was swapping out an older switch for one of these. When I plugged a 1000base-SX SFP module in the system is reading it as a 10G LR module. We are running version 17.03.03. When doing a show inventory it does show the proper SN of the module.
15 Replies 15
Leo Laohoo
Is the SFP a non-Cisco branded variety?
No, it is a Cisco Systems 30-1301-01 GLC-SX-MM
marce1000
          - Check SFP compatibility with : https://tmgmatrix.cisco.com/?npid=1767
 M.
According to what was found on the Matrix the GLC-SX-MM is supported.
If you have a third party vendor SFP you can use the following hidden commands:
no errdisable detect cause gbic-invalid
service unsupported-transceiver
****Kindly rate all useful posts*****
This is a Cisco Systems branded module.
Please post the complete output to the following command:  sh idprom interface <SFP PORT>
Make sure the optic is in the port when entering the command (above).
General SFP Information
Identifier : SFP/SFP+
Ext.Identifier : SFP function is defined by two-wire interface ID only
Connector : Fibre Channel Style 2 copper connector
Transceiver
10/40GE Comp code : 10G BASE-LR
SONET Comp code : OC 192 short reach
GE Comp code : 1000BASE-SX
Link length : Intermediate distance
Technology : Shortwave laser with OFC
Media : Miniature Coax
Speed : 1600 MBytes/Sec
Encoding : Unknown
BR_Nominal : 3200 Mbps
Length(9um)-km : 32 km
Length(9um) : 3200 m
Length(50um) : 320 m
Length(62.5um) : 320 m
Length(Copper) : 320 m
Vendor Name : CISCO-FINISAR
Vendor Part Number : GLC-SX-MM
Vendor Revision : 0x35 0x2E 0x30 0x20
Vendor Serial Number : H19H396
Wavelength : 850.32 nm
CC_BASE : 0xF3
Extended ID Fields
Options : 0x20 0x20
BR, max : 0x20
BR, min : 0x20
Date code : 070227
Diag monitoring : Not Implemented
Internally calibrated : No
Exeternally calibrated: No
Rx.Power measurement : OMA
Address Change : Not Required
CC_EXT : 0xAE
Other Information
Chk for link status : 00
Flow control Receive : Off
Flow control Send : Off
Administrative Speed : 10000
Administrative Duplex : full
Operational Speed : auto
Operational Duplex : auto
SEEPROM contents (hex):
0x00: 03 04 03 20 20 20 01 20 20 20 20 20 20 20 20 20
0x10: 20 20 20 20 43 49 53 43 4F 2D 46 49 4E 49 53 41
0x20: 52 20 20 20 01 20 20 20 47 4C 43 2D 53 58 2D 4D
0x30: 4D 20 20 20 20 20 20 20 35 2E 30 20 03 52 20 F3
0x40: 20 20 20 20 48 31 39 48 33 39 36 20 20 20 20 20
0x50: 20 20 20 20 30 37 30 32 32 37 20 20 00 00 00 AE
0x60: 00 00 11 80 8F 64 32 C9 A2 1A C6 9F F1 68 5D AB
0x70: F9 1B C7 00 00 00 00 00 00 00 00 00 29 19 21 14
Optics is made by Finisar and it is showing to be a GLC-SX-MM but the switch is saying it is a SFP-10G-LR.
This is a bug with the firmware.  I recommend upgrading to 17.9.3.
I will do that and let you know the results.
Upgraded to 17.9.3 still have the same result.
Interesting results.
Do not bother raising a TAC Case.  IF the TAC agent sees the optic is an end-of-support GLC-SX-MM the case would only be closed or terminated.
Try talking to your Cisco AM/SE but I doubt any good it will do.
marce1000
 - Have a test with this (advisory) release : https://software.cisco.com/download/home/286320046/type/282046477/release/Bengaluru-17.6.5
 M.
As soon as the cisco site allows me to actually download it, I will be testing that version.
