udp-small-servers
polaris
What does this command do? I searched the other forums and found just one reply to a similar request. It was very general and of not much use. I also searched Cisco's web site for this and found no real info. Can anyone tell me if this can be used for troubleshooting and how?
Sam
7 Replies 7
thisisshanky
Level 11
Level 11
There are some services, like echo, discard, chargen etc, which use either tcp or udp protocol. If you enabled this service, (either tcp-small-servers or udp-small-servers) these services will be enabled. Usually these should be disabled on a router, as these ports if are remaining open, a hacker from the internet can hack into your network.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
bbranch
Level 3
Level 3
The following URL on CCO covers these commands in some detail:
http://www.cisco.com/warp/customer/66/23.html
bbranch,
Thanks for your reply; that was exactly what I was looking for...
Sam
This link is now broken
Hi @raptorexelic ,
Try this one instead.
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-110/12815-23.html
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Thanks Harold. I was just skimming through some articles and noticed (in case OP wanted to update his link).
Hi @raptorexelic ,
The original post is from 2002, so the OP might have retired
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
